Configuring Siebel eBusiness Applications > Overview of Configuring Siebel Applications > Other Ways to Customize Application Behavior >
Siebel ePricer
Siebel ePricer provides a solution for creating, assessing, administering, and deploying flexible pricing strategies. Siebel ePricer consists of the following:
  • A set of administration views that allow you to define pricing adjustments and the conditions under which they should be applied.
  • An engine that evaluates the condition statements and determines which pricing adjustments should be applied.
  • A testing area that allows assessment of the pricing adjustments.
  • Integration with end-user interfaces, such as Quotes, Orders, Siebel eSales, Siebel PRM, and Siebel eConfigurator.
Siebel ePricer is composed of the following components:
  • Price lists. Contain base prices.
  • Pricing models. Management tool to control a set of related pricing factors.
  • Pricing factors. Statements that define conditions and pricing adjustments.
  • Scripting. Lets you use business services with a pricing factor to extend the pricing calculation and to access external data.
  • Pricing validation. Lets you test pricing factors and the pricing model before releasing for use by end users.
  • Reports. Lets you print reports of pricing factors.
  • Pricer Engine. Evaluates conditional statements and applies pricing adjustments.
For more information on accessing and using the State Model views, see Pricing Administration Guide.
