Configuring Siebel eBusiness Applications > Configuring Picklists and Pick Applets > About Dynamic Picklists > About Dynamic Picklist ObjectsThe field of the originating control references the Pick List object definition. The Pick List object definition identifies the pick business component. In this way, the identity of the pick business component is made known to the pick applet. Figure 83 shows the detailed definition of the Pick List object definition from Figure 78. The Pick List object definition has the following important property, when used in pick applet configuration: Business Component. This property identifies the pick business component. NOTE: When configuring a pick applet invoked from a multi-value group applet, define the picklist on the originating field in the originating business component, not on fields in the multi-value group business component. For more information on multi-value group applets, see Configuring Multi-Value Group and Association Applets. |
Configuring Siebel eBusiness Applications |
