Configuring Siebel eBusiness Applications > Configuring Picklists and Pick Applets > About Static Picklists >
About the Originating Applet of a Static Picklist
The originating applet (Applet object type) has the following important properties:
  • Business Component. Identifies the originating business component.
The originating control (Control object type) or list column (List Column object type) has the following important properties:
  • Field. Identifies the originating field in the originating business component.
  • Pick Applet. Leave blank for a static picklist.
  • Runtime. Set to TRUE to indicate that a static picklist is attached, and needs to be activated in response to a user click on the control or list column.
