Configuring Siebel eBusiness Applications > Configuring Special Purpose Applets > Understanding How Chart Applets Are Constructed >
Charts with Two Y Axes
Two line graph curves can appear in the same Chart, plotted against different Y axes (one to the left of the graph, the other to the right). Any field or function combination can be used on the left Y axis, and likewise for the right. To accomplish this, set the following property values in the Chart object definition:
  • Data Point Field. Specify two fields, separated by a comma. The first is for the left Y axis, the second is for the right Y axis.
  • Data Function. Specify two functions, separated by a comma. The first is for the left Y axis, the second is for the right Y axis.
  • Type. Set to Combo.
