Configuring Siebel eBusiness Applications > Configuring Special Purpose Applets > Understanding How Chart Applets Are Constructed >
Chart Element Object Type
Chart Element is a child object type of Chart. The following types of Chart Elements (as specified in the Type field in the Chart Element object type) are supported:
  • AxisLabel. Displayed along each axis, with one label for each division of the axis.
  • AxisLineGrid. Grids make it easier to comprehend a Chart. You can set various grid properties, such as grid color, width, and visibility, on an axis-by-axis basis.
  • AxisTitle. Displayed along each axis, with one title per axis.
  • Graphic. A line, rectangle, or ellipse used to emphasize a region of the Chart.
  • Legend. The list of colored rectangles with accompanying category labels on the left side of the Chart.
  • Plot. The area that contains the graphs, usually in the center of the Chart.
  • Title. The large string of text, usually at the top of a Chart.
  • Font, Color, and Size. For most Chart Elements that contain text, you can set such text properties as font, color, and size.
  • Fill color. You can set the fill color of the Chart and Plot Chart Element types.
The properties of the Chart Element that apply to the axis label for the X axis (Coordinates, Display Format, Divisions, List Of Values, Sort Specification, and Text) should not be used when specifying a list of X axis source fields, as they can be relevant only for one X axis field. Also, the text of the X axis title is determined dynamically from the combo box selection if the By combo box provides a list of source fields. Whatever is in the Text property in the AxisTitle chart element for the X axis is overridden at run time.
The same restrictions are relevant for the Z axis.
