Configuring Siebel eBusiness Applications > Configuring Special Purpose Applets >
Using the Tree Applet Wizard
The following procedure identifies the steps required to create a new tree applet using the Tree Applet Wizard.
NOTE:  The Tree Applet Wizard creates the tree object but does not create Tree Node child objects. You must add a Tree Node object for each applet that you want to appear in the Explorer section of the view, including the top-level node, such as service requests. For more information, see Tree Node.
To create a tree applet using the Tree Applet Wizard
  1. From the Tools main menu, choose File > New Object.
    The New Object Wizard dialog box appears.
  2. Select the Applets tab and then select the Tree Applet icon.
  3. In the General dialog box, enter the following information, and then click Next:
    • Project
    • Business Component
    • Name
    • Display Name
  4. In the Web Layout-General dialog box, select the Web template to use for the tree applet, and then click Next.
    Some templates used for tree applets are:
    • Applet Tree
    • Applet Tree 2
    • Applet Tree Marketing
  5. In the Finish dialog box, review the information, and then click Finish.
    The Tree Applet Wizard creates the tree object and sets the required properties based on the information you entered.
