Configuring Siebel eBusiness Applications > Configuring Special Purpose Applets >
Pop-Up Windows
This section describes how to create pop-up windows and dialog boxes. There are various scenarios in which pop-up windows are implemented:
When configuring pop-up windows, consider the following:
- Pop-up applets must use classes derived from CSSSWEFramePopup. Business components are not required for the applets. However, if your pop-up applet is associated with a business component, that business component must be a child of the business object of the view containing the applet from which the pop-up window is launched.
- One level of pop-up window is supported. If you activate a pop-up window from within a pop-up window, it replaces the original pop-up window.
- The More/Less feature is not supported on Pop-up applets. See Configuring Controls and List Columns to Appear in More Mode Only for more information.
