Configuring Siebel eBusiness Applications > Configuring Special Purpose Controls > Setting Properties in an ActiveX ControlAn ActiveX control includes its own property list, which varies from control to control. In addition, an ActiveX control in an applet has the full set of properties of the Control object type. There are two ways to view and modify properties for an ActiveX control in an applet: by using the Properties window, or by activating the control's built-in property sheet. To change properties in the Properties window
The changes you make to the control's native properties are generally displayed in the Applet Web Template Layout window, such as when you change a text color or font property. Additionally, changes you make to the control's native properties are saved with the applet, just as with the Siebel properties. The alternative approach to changing property settings is to use the control's native property sheet. When you make property changes using the control's native property sheet, you can modify only the properties of the ActiveX object, not those of the standard control object definition. To alter the standard control properties, you must use the Properties window. To change properties in the ActiveX control's native property sheet
Configuring Siebel eBusiness Applications |
