Configuring Siebel eBusiness Applications > Configuring Spell Check >
Adding Spell Check Button to a Web Template
To edit the Web Applet
- In the Object Explorer, double-click the Applet object type to expand it.
- In the Applets window, select the name of the applet for which you are creating a Spell Check button, and then right-click and choose Edit Web Layout.
- In the Web Control toolbar, from the Mode drop-down list, select Edit.
- In the Controls window, select the "Check Spelling" icon, and then drag it to a placeholder in the Web template.
- In the Web template, right-click and choose Preview.
You can see the Spell Check button as it will appear in the user interface.
