Configuring Siebel eBusiness Applications > Configuring Tables and Columns >
Process for Extending the Data Model
When extending the data model, perform the following tasks:
  1. Check out projects that contain the tables you want to modify.
    For information about checking out of projects, see Using Siebel Tools.
  2. Make the requisite changes to the logical schema, such as creating tables, columns, or indexes. Tasks may include:
  3. Applying Database Extensions to the Local Database
  4. Preparing Server Database for Applying Schema Changes
  5. Applying Data Model Changes to the Server Database
  6. Propagating Changes to Other Local Databases
