Configuring Siebel eBusiness Applications > Configuring Tables and Columns > Modifying Extension Tables or ColumnsYou may need to modify your extension tables or columns after creating or activating them. You can modify properties of extension tables or columns only. Modification of standard base tables and their columns is not supported. You can rename a column prior to applying it to the server. However, once the column has been added or applied to the server, you cannot simply rename the column and must deactivate the existing column and create a replacement extension column. NOTE: You cannot modify the static extension tables that are preconfigured with Siebel applications. See About Extension Tables. To modify an existing extension column
To rename an existing extension column
To modify an existing extension table
NOTE: Be careful when modifying the Physical Type property for columns; depending on existing data in the column, changes may not be possible. |
Configuring Siebel eBusiness Applications |
