Configuring Siebel eBusiness Applications > Configuring Tables and Columns >
Preparing Server Database for Applying Schema Changes
After you have tested your extensions in the local environment, complete the following actions before applying the changes to the server database:
  • Have all mobile users to synchronize.
  • Make sure all connected clients are disconnected from the database server.
  • Once all mobile user transactions have been merged and routed, stop all Siebel Servers.
  • Perform a full backup of the database.
