Configuring Siebel eBusiness Applications > Overview of Web Templates and Siebel Tags > About Using the Thread Bar in TemplatesThe thread bar is used to track user navigation among the views. A thread bar in HTML text format has been implemented. An example of the thread bar is as follows:
Home, Consumer:PCs, and so on are the thread buttons. The thread buttons are displayed in title: value format, and either title or value can be omitted when appropriate. The thread button may contain a hyperlink, which leads the user to a previous page. The thread buttons are separated by separators— ">" in the above example. A thread button may have a hyperlink that leads the user to a previous page. The hyperlink requires a new SWE Command: GotoBookmarkView. The hyperlink for each thread button should contain at least the following parameters: SWECmd=GotoBookmarkView&SWEBMCount=2SWECount =3 The SWEBMCount = 2 indicates that bookmark #2 will be used to create the view. SWECount=3 is the bookmark ID for the current view. With the definition of the swe tags and thread link format, a thread button for account A.K. Parker will be translated into HTML format as: <a href = " www.siebel.com/start.swe?SWECmd=GotoBookmarkView&SWEBMCount=2& SWECount=3> Account: AK Parker </a> A new bookmark is created when the user clicks the thread button and brings back a bookmarked view. The bookmark ID for the new view is the current swe count (the count passed to the server in the request) increased by 1. Bookmark deletion policy is not modified with the above bookmark ID assignment policy. By default, the system keeps the most recently created 20 bookmarks and deletes previous ones. If the swe count in the user request is less than the swe count on the server side, all the bookmarks with a swe count larger than what is in the user request is deleted. The behavior of the HTML threadbar is summarized below:
When a thread button is clicked, the thread proceeds to the step view indicated by SWEBMCount. The following three swe tags are defined to create an HTML thread bar. The usage of these swe tags is very similar to that of the screen bar and view bar tags.
The To use a thread bar, insert thread bar definitions into an appropriate SWT file by using the tags defined above. An example is given below: <!-- Begin Threadbar section --> <table class="Theadbar" width=100% border="0" cellspacing="0" cellpadding="0"> <td nowrap bgcolor="#6666CC" width=110> <img src="images/spacer.gif" width="110" height="25" border="0"> <img src="images/spacer.gif" width="10" height="25" border="0" align="absmiddle"> <swe:threadlink property="FormattedHtml"> <font color="#000000"> <span > <nobr><swe:this property="Title"/></nobr> </span> </font> <swe:stepseparator>></swe:stepseparator> <img src="images/spacer.gif" width="10" height="25" border="0" align="absmiddle"> <!-- End Threadbar section --> This creates a thread bar as shown below: Home > Consumer:PCs > PCs:Laptops For applications without frames, put the definition in a container page such as CCPageContainer.swt; for applications with frames, insert it in the "Viewbar" frame swt file or View frame swt file. |
Configuring Siebel eBusiness Applications |
