Siebel Financial Services Connector for ACORD P&C and Surety Guide > Troubleshooting > Run-Time Event Setup Problems in Workflows > Object Id is not passed to the workflowProblemThe Object Id is not passed to a workflow correctly when using Runtime Event Management to trigger the workflow. SolutionThe business object name of the workflow is not set up correctly. Please select the business object name desired. |
Siebel Financial Services Connector for ACORD P&C and Surety Guide |
