Siebel Financial Services Connector for ACORD P&C and Surety Guide > Overview > Using the Siebel Connector for ACORD XMLThis chapter provides a brief overview of the capabilities of the Siebel Connector for ACORD XML. Additional information about integration with Siebel eBusiness Applications is available in:
Your work with the Siebel Connector for ACORD XML consists of:
You can learn how to build the transformation maps and create workflows from this guide. You can also use some out-of-the-box ACORD messages and workflows defined in this guide as your reference for implementation. Some information on customizing your integration is included in this guide, but you will also need to consult additional guides specified in the text. Major chapters in this guide provide a description of ACORD rules and syntax, the methods and arguments for configuring a Siebel Connector for ACORD XML to customize your integration solution, and a sample implementation showing the steps involved to configure and use the connector. |
Siebel Financial Services Connector for ACORD P&C and Surety Guide |
