Siebel Financial Services Connector for ACORD P&C and Surety Guide > Siebel Connector for ACORD XML >
FINS ACORD XML Converter
The purpose of the FINS ACORD XML Converter is to generate and process ACORD-specific elements, such as the <SignonRq> aggregate and the <SignonRs> aggregate.
The FINS ACORD XML Converter receives hierarchy output and converts it into a property set or an XML string.
