Siebel Financial Services Connector for ACORD P&C and Surety Guide > Siebel Connector for ACORD XML > FINS ACORD XML Dispatcher >
Dispatcher Methods and Arguments
The FINS ACORD XML Converter methods and arguments are described in the following tables. Table 20 describes the FINS ACORD XML Dispatcher method.
Table 20. Dispatcher Method
Method
Display Name
Description
DispatchMessage
DispatchMessage
Validates the incoming XML message. If the message conforms to the dispatching rules, the integration object names and other necessary information will be attached to the message.
It also checks for the envelope, header, and fault sections of the message and identifies them.
Table 21 describes the argument for the DispatchMessage method.
Table 21.  Method Argument for DispatchMessage Method
Argument
Value
Description
XMLHierarchy
Hierarchy name.
Property set in external integration object
XML hierarchy.
Table 22 provides specifications for the DispatchMessage method argument.
Table 22. Argument for DispatchMessage Method
Name
Display Name
Data Type
Type
Optional
XMLHierarchy
XML Hierarchy
Hierarchy
Input/Output
No
