Deployment Planning Guide > Siebel Architecture Overview > About Siebel Enterprise Application Integration (EAI)Siebel EAI provides components for integrating Siebel Enterprise Applications with external applications and technologies. It is designed to work with third-party solutions such as those from IBM, CrossWorlds, TIBCO, Vitria, SeeBeyond, webMethods, and others. Siebel EAI provides bidirectional real-time and batch solutions for integrating Siebel applications with other applications. It also includes tools for cross application integration through Universal Application Network (UAN). Siebel EAI is designed as a set of interfaces that interact with each other and with other components within the Siebel application. These interfaces are compatible with IBM MQSeries; Microsoft MSMQ, BizTalk, and OLE DB; Sun Microsystems Java and J2EE; XML, and HTTP, and many other standards. These interfaces do the following:
For more information on EAI, see Overview: Siebel Enterprise Application Integration Volume I. |
Deployment Planning Guide |
