Deployment Planning Guide > Siebel Client Deployment Planning > About Standard and High Interactivity ModesIn the Web browser, Siebel applications run in one of two modes: standard interactivity or high interactivity. High interactivity is designed to provide Siebel applications with a user experience similar to that of traditional GUI-based Windows applications. High interactivity reduces the number of page refreshes, compared to standard interactivity—when interacting with the application, browsing through records, and so on. This is made possible by requesting data-only updates from the server. The application thus makes optimal use of network bandwidth. For example, a high interactivity client does not require a page refresh for creating a new record. A user creates a new record by clicking New. A new row is created in a list dynamically, without a page refresh. The user enters the relevant data, then clicks outside of the record to implicitly commit the change—again, without a page refresh. Some of the features of the high interactivity framework are:
The high interactivity framework requires the Microsoft Internet Explorer browser running in a Windows environment and uses both ActiveX controls and Java. For a list of supported browser versions, see System Requirements and Supported Platforms on Siebel SupportWeb. Deploying Siebel applications in high interactivity mode requires adhering to strict guidelines regarding the deployed operating system, Internet Explorer version and settings, and Java software environment. For a discussion of which Siebel applications must be deployed in high interactivity mode and the related browser requirements, see Siebel System Requirements and Supported Platforms. |
Deployment Planning Guide |
