Developing and Deploying Siebel eBusiness Applications > Getting Started with Siebel Tools > Using Siebel ToolsSiebel Tools is a declarative software development environment used to create and modify object definitions in the Siebel repository. Using Siebel Tools you can configure a standard Siebel application without modifying source code or SQL code. NOTE: You use an HTML code editor, not Siebel Tools, to modify Web templates. However, you can also view a color-coded rendition of Web templates using the Web Template Window in Siebel Tools. You can also specify a default HTML editor to open from within the Siebel Tools application. For more information, read Setting Tools Options. |
Developing and Deploying Siebel eBusiness Applications |
