Developing and Deploying Siebel eBusiness Applications > Configuring the House and Opportunity Entities > Configuring the House Detail - Appraisals View >
Adding the House Detail - Appraisals View to the Houses Screen
After you have created the view, you need to associate it with a screen. In this case, NREC adds the House Detail - Appraisals View to the Houses Screen. For the detailed procedure, read Creating the House Detail View.
To associate the House Detail - Appraisals view to the Houses Screen
  1. Create a symbolic string with the text "Appraisals". Use the procedure To create a symbolic string.
  2. In the Object Explorer, expand the Screen object type.
    The Screens window appears in the Object List Editor.
  3. In the Screens window, select the NREC House Screen.
  4. In the Object Explorer, select the Screen View object type (child of Screen).
  5. In the Screen View window, add the record as shown in the following table.
    Field
    Value
    View
    Type
    Detail View
    Parent Category
    NREC
    Viewbar Text
    Appraisals
    Menu Text
    Appraisals
