Developing and Deploying Siebel eBusiness Applications > Configuring the House and Opportunity Entities > Configuring the Opportunity Details View >
Adding Fields to the Opportunity Business Component
After extending the database to support NREC's additional attributes, you need to define the fields in the business object layer. You do this by adding the fields to the Opportunity business component. The fields map to the extension columns in the S_OPTY. The steps covered in this procedure are at a high-level. For detailed instructions, review the procedures covered in Configuring the Internal Product Business Component.
To add fields to the Opportunity business component
  1. Navigate to the Opportunity business component.
  2. Lock the project locally, and then change the value of the Project property to NREC Configuration.
  3. Add the fields as shown on the following table.
    Name
    Column
    Agent
    X_AGENT
    Number of Bathrooms
    X_BATHROOMS
    Number of Bedrooms
    X_BEDROOMS
    Price Range
    X_PRICE_RANGE
    Square Feet
    X_SQUARE_FEET
    These fields are now available to expose in the user interface.
