Developing and Deploying Siebel eBusiness Applications > Deploying the Application > Migrating Data from the Test Environment to Production > Moving Program DataYou must move program data, specifically Assignment Manager, Workflow and Personalization data from the test environment (where you created it) to the Production environment, as described in this section. Moving Assignment Manager DataYou can use EIM to move your Assignment Manager data. To move Assignment Manager data For more information about EIM, read Siebel Enterprise Integration Manager Administration Guide. Moving Workflow DataMoving Workflow data consists of moving data about workflow processes and moving data about workflow policies and groups. Moving each of the two types of data requires you to follow a different procedure.
NOTE: When exporting a process containing subprocesses, you must also export the subprocesses. Subprocesses are not exported automatically. To import a process definition
NOTE: If a process definition of the same name exists in the target environment, the newly imported process definition's version number increments by one. To move workflow policies and groups For more information about EIM, read Siebel Enterprise Integration Manager Administration Guide. Moving Personalization DataPersonalization rules, events, and actions can be exported as an XML file for later importation into another Siebel environment. Exporting Personalization Data as an XML FilePersonalization data rules, events, and actions are exported in one XML file. To export personalization data as an XML file
Importing Personalization DataPersonalization rules, events, and actions can be imported from an XML file generated by a previous export. This process can take several minutes. To import personalization data from an XML file
Developing and Deploying Siebel eBusiness Applications |
