Developing and Deploying Siebel eBusiness Applications > Installing Siebel Applications >
The Production Environment
The software you install in your production environment is typically the same as the software installed in the test environment (shown in Table 7). Eventually, during rollout to users, you copy the contents of one of the client machines to your mobile Web Client machines. Also, you distribute a URL to your application to your Web Client users.
NREC installed the Production software on machines with names starting with PROD. For example, it installed the server-side software on PROD_server.
