Developing and Deploying Siebel eBusiness Applications > Pick Lists, Drilldowns, and MVGs > Configuring Multi-Value Groups > Exposing the MVG in the User InterfaceAfter you create the underlying objects necessary to display the MVG, you can expose the multi-value field in the user interface. The Opportunity Form (SCW) applet already has a Contact field. It needs to be redefined so it shows the Contact MVG. To expose the MVG in the user interface
Developing and Deploying Siebel eBusiness Applications |
