Developing and Deploying Siebel eBusiness Applications > Required Application Administration Tasks > Setting Up Users > Associating Responsibilities with a UserWhen you are first implementing your Siebel application, you define responsibilities, as described in Defining Responsibilities. After you have defined responsibilities, you assign them to users as described in Setting Up Users. Using this process you can assign user responsibilities at the same time as you enter other user information. After your initial implementation, you may work directly from the Responsibility view, or you may continue to work from the Employee view to change or add associations between users and their responsibilities. To associate a user with a responsibility
Developing and Deploying Siebel eBusiness Applications |
