Developing and Deploying Siebel eBusiness Applications > Required Application Administration Tasks >
Logging On as the Siebel Administrator
To perform the tasks in this chapter, you must log in to your Siebel application using the administrator user name and password assigned by your database administrator. The default values are SADMIN/SADMIN. You can use SADMIN/SADMIN to log in to the Siebel Sample database to complete the tasks in this chapter.
To log in as an administrator to a server data source
  1. Open your Web browser.
  2. Go to the URL for your application.
    The login screen appears.
  3. Enter SADMIN in the User ID and Password fields.
  4. Click OK.
    Logging in as SADMIN provides access to all screens and views mentioned in this guide.
To log in as an administrator to the sample data source
  1. Open the Mobile Web Client on your local machine.
    For the NREC example, log in to Siebel Partner Manager.
  2. Enter SADMIN/SADMIN as the user name and password.
  3. Select Sample as the data source.
    Siebel Partner Manager opens, displaying data from the Sample database.
    NOTE:  If you modified tabs as described in Modifying the Look and Feel of the Web Client the images for the off state may appear in your employee application. To return the user interface to the original look and feel, you need to replace the original images. For more information about tab images, read Modifying the Screen Bar and View Bar Colors.
