Developing and Deploying Siebel eBusiness Applications > Required Application Administration Tasks > Defining Company Structure > Setting Up Organizations and Organization SkillsSetting up organizations is an optional step in an implementation. If you do not set up additional organizations, you automatically have everything assigned to a default organization. Having one organization is like having no organization. There is no effect on visibility and data access. Because NREC is using Partner Portal, it sets up one parent organization called NREC and then a child organization for each of its partner real estate agencies. This structure lets NREC to logically group these different user groups and partition data accordingly. Initially NREC creates the NREC organization. Then after the rest of the company structure is set up—positions, responsibilities, and so on—NREC uses Siebel Partner Manager to set up partners and promote them to organizations with NREC as the parent organization. Read Registering Partners and Creating Partner Organizations. For more information on organizations and company structure, read Applications Administration Guide.
Developing and Deploying Siebel eBusiness Applications |
