Developing and Deploying Siebel eBusiness Applications > Creating a Virtual Business Component >
Creating a Link
The relationship between houses and house renovations is one to many (1:M); there can be many renovations recorded for one house. Therefore, you need a link to create the parent-child relationship between the Internal Product business component and the NREC Renovations VBC business component. Internal Product is the business component that NREC is using to store houses. See NREC's entity relationship diagram shown in Figure 3.
To create a link between parent and child business components
  1. Select the Link object type.
  2. In the Links window, add a new record as shown in the following table.
    Field
    Value
    Description
    Name
    Internal Product/NREC Renovations VBC
    Unique name for the link.
    Project
    NREC Configuration
    Project to which the object belongs.
    Parent Business Component
    Internal Product
    Parent business component.
    Child Business Component
    Child Business component.
    Source Field
    Part #
    Unique ID on the parent record. Often this field is Row Id. In this case, the unique field is a manually entered value.
    Destination Field
    House_ID
    Column in the child record that stores the parent ID.
