Developing and Deploying Siebel eBusiness Applications > Creating a Virtual Business Component > Exposing the Fields in the User Interface >
Creating a New List Applet
To display the data from the NREC Renovations VBC you must create a new applet. The NREC design specifies a standard list applet. To create it you use the List Applet New Object wizard. In the next section, you create a master-detail view to contain the applet.
To create a new list applet to display renovation data
  1. Choose File > New Object.
    The New Object dialog box appears.
  2. Click the Applets tab and then select List Applet.
  3. Complete the wizard using the values as shown in the following table.
    Field
    Value
    Project
    NREC Configuration
    Applet Name
    Renovations List Applet
    Display Title
    Renovations
    Business Components
    Web Templates
    Base: Applet List (Base/List Edit)
    Edit List: Applet List Edit (Edit/New/Query)
    Edit: Applet List Edit (Edit/New/Query)
    Fields
    House_ID, Date, Description
    Controls
    Accept default controls selected for the applet.
