Developing and Deploying Siebel eBusiness Applications > Creating a Virtual Business Component > Understanding Virtual Business ComponentsVirtual business components (VBCs) bring data from external data sources into your Siebel application user interface. For example, you could create a VBC to represent data from data sources such as: Virtual business components are based on business services. Business services determine the behavior of the VBC and define how the VBC manipulates data. You can base VBCs on predefined business services provided by Siebel Systems, such as the XML Gateway, or you can create your own business service. You create both virtual business components and business services in Siebel Tools. |
Developing and Deploying Siebel eBusiness Applications |
