Developing and Deploying Siebel eBusiness Applications > Creating a Virtual Business Component > Creating a Virtual Business Component >
Creating Fields for the Virtual Business Component
After creating the virtual business component you need to create the fields to display in the Siebel application. These fields display data retrieved from the House Renovations file shown in Figure 26.
NREC's requirement is to define the following fields for the business component:
  • Date
  • Description
  • House_ID
To add fields to the virtual business component
  1. In the Object Explorer, expand the Business Component Object type.
  2. In the Object List Editor, select NREC Renovations VBC.
  3. In the Object Explorer, select Single Value Field object type (child of Business Component).
  4. Enter each of the records as shown in the following table.
    Name
    Type
    Comments
    Date
    DTYPE_TEXT
    Date the renovation was recorded
    Description
    DTYPE_TEXT
    Description of the renovation
    House_ID
    DTYPE_TEXT
    House Identification Number
