Developing and Deploying Siebel eBusiness Applications > Siebel Business Process Designer > Activating the Rules >
Starting Workflow Monitor Agent
You must start two Workflow Monitor Agent tasks: one for Assignment Manager and the other for Workflow policies. To create a Workflow Monitor Agent component definition
- Navigate to Administration - Server Configuration > Enterprises.
The Enterprise Configuration view appears.
- Click the Component Definitions tab.
Two Component Definitions lists appear.
- From the upper Component Definitions list menu, choose New Record.
A new record appears.
- Complete the fields as shown in the following table.
Name |
NREC's WorkMon |
Name of the component. |
Component Type |
WorkMon |
Worfkow Monitor Agent component type. |
Component Group |
NREC Workflow Component Group |
Select an existing component group. |
Alias |
NRECWorkMon |
Alias for the component. The alias can not contain blank spaces. |
- From the upper Component Definitions list menu, choose Save Record.
The component definition is saved. To view the definition, you must perform a query.
To set parameters and activate a Workflow Monitor Agent component definition
- In the upper Component Definitions list, perform a query for the component definition.
- In the lower Component Definitions list, choose the Group Name parameter. Enter the name of the Workflow Policy Group for the requests the component will process.
- In the lower Component Definitions list, choose the Default Tasks parameter. Set the Value to 1.
This sets the component to start when the Siebel server starts, and stop when the Siebel server shuts down.
- Optional. You may make additional changes to the component parameters. For a description of Workflow Monitor Agent parameters, read Siebel Business Process Designer Administration Guide.
- From the upper Component Definitions list menu, choose Enable Component Definition.
The definition state changes from Creating to Active.
- Restart the Siebel server.
Your changes take effect.
