Overview: Siebel Enterprise Application Integration > Siebel EAI Overview > About the Components of Siebel EAI > Siebel External Business ComponentsExternal Business Components (EBCs) provide a way to access and view relational data sources that reside in a non-Siebel table or view using a Siebel business component. Unlike VBCs that require a business service, EBCs can use Siebel's database connectors to access data. EBCs are configured in Siebel Tools using a Table object definition in the Siebel Repository and a physical table that resides in the same Siebel database instance or subsystem that contains other Siebel tables. |
Overview: Siebel Enterprise Application Integration |
