Overview: Siebel Enterprise Application Integration > Siebel EAI Overview > About Preconfigured Integration Solutions > Siebel EAI Prebuilt ConnectorsSiebel Systems and its partners provide prebuilt, end-to-end, functional integration for major packaged applications. These connectors use data and cross-application process integration services provided by the Siebel Business platform (see About Siebel EAI). For each supported business process, the connectors include built-in data mapping between the exchanged entities, as well as sequencing and error handling. Siebel Connector for SAP R/3Siebel Connector for SAP R/3 allows integration between Siebel applications and SAP R/3. The Siebel Connector for SAP R/3 provides an infrastructure that allows Siebel Business Applications to interact with SAP R/3 through standard SAP R/3 technologies. It virtually eliminates the need to code components for transforming and routing data between Siebel applications and SAP R/3. The connector supports both SAP's Business APIs (BAPIs) for real-time interaction and Application Link Enabling (ALE/IDOC) for asynchronous integration. |
Overview: Siebel Enterprise Application Integration |
