Integration Platform Technologies: Siebel Enterprise Application Integration > External Business Components > Usage and Restrictions for External Business ComponentsThe following usage guidelines and restrictions apply to EBCs:
NOTE: Significant configuration effort and changes may be required if you choose to reconfigure a standard Siebel business component on an external table. For example, existing join and link definitions are unlikely to function, because the source fields and underlying columns may not exist in the external table. |
Integration Platform Technologies: Siebel Enterprise Application Integration | Copyright © 2008, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
