Integration Platform Technologies: Siebel Enterprise Application Integration > Siebel EAI and File Attachments > Using Inline XML to Exchange Attachments >
Creating an Attachment
You create an attachment to a record in the Siebel client whose row ID you know. To create the attachment
- In the Siebel client, navigate to a record that can take an attachment, for example, an account.
- Choose Help, then About Record from the application-level menu to obtain the row ID of the record.
- Drill down on the record, then select the Attachments tab.
- Add an attachment to the record if none exists.
