Integration Platform Technologies: Siebel Enterprise Application Integration > Creating and Maintaining Integration Objects >
Best Practices for Maintaining Siebel Integration Objects
Sometimes you may change the underlying business objects, which necessitates maintenance of the integration object. Synchronize the integration object by clicking the Synchronize button.
To make maintenance of integration objects easier, adhere to the following guidelines when creating or editing your integration objects:
  • Name any user key that you add, which is different from the generated user keys. Using meaningful names helps with debugging.
  • Inactivate user keys instead of deleting them.
  • Inactivate fields instead of deleting them.
Integration Platform Technologies: Siebel Enterprise Application Integration Copyright © 2008, Oracle and/or its affiliates. All rights reserved. Legal Notices.
