Integration Platform Technologies: Siebel Enterprise Application Integration > Creating and Maintaining Integration Objects > Validating Integration ObjectsWhen you have created your integration object and made the necessary modifications to meet your business requirements, you must validate your integration object. To validate your integration object
NOTE: The integration objects you create in Siebel Tools must be compiled into the Siebel.srf file. When you test the integration object, you must copy the compiled SRF to your |
Integration Platform Technologies: Siebel Enterprise Application Integration | Copyright © 2008, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
