Table 5. Integration Object Base Object Types
None |
For internal use only. |
OLE DB |
Used to expose Siebel business component as an OLE DB rowset that can be used by OLEDB consumers such as Excel, Word, and so on. The OLE DB Provider only accepts integration objects of this type. |
SAP BAPI Input |
Used to represent the input structure of an SAP RFC or BAPI function call. For information, see the Siebel Connector for SAP R/3 Guide. |
SAP BAPI Output |
Used to represent the output structure of an SAP RFC or BAPI function call. For information, see the Siebel Connector for SAP R/3 Guide. |
SAP IDOC |
Used with the IDOC Adapter and Receiver in version 6.x and 7.0. For information, see the Siebel Connector for SAP R/3 Guide. |
SAP IDOC Adapter |
Used to represent an SAP IDOC structure. For information, see the Siebel Connector for SAP R/3 Guide. |
SQL |
Used for manually creating integration objects. Only the EAI SQL Adapter accepts integration objects of this type. |
SQL Database Wizard |
Used by the Database Wizard for the integration object it creates. Only the EAI SQL Adapter accepts integration objects of this type. |
SQL Oracle Wizard |
Used by the Oracle Wizard for the integration object it creates. Only the EAI SQL Adapter accepts integration objects of this type. |
Siebel Business Object |
Used by the Integration Object Builder wizard for the integration object it creates. The EAI Siebel Adapter accepts only the integration object of this type. |
Table |
Obsolete. |
XML |
Used to represent external XML Schema such as DTD or XSD. For information on DTD and XSD, see XML Reference: Siebel Enterprise Application Integration. |
