Integration Platform Technologies: Siebel Enterprise Application Integration > Property Set Representation of Integration Objects >
Property Sets and Integration Objects
Many EAI business services operate on integration object instances. Because business services take property sets as inputs and outputs, it is necessary to represent integration objects as property sets. The mapping of integration objects, components, and fields to property sets is known as the Integration Object Hierarchy. Using this representation, you can pass a set of integration object instances of a specified type to an EAI business service. You pass the integration object instances as a child property set of the business service method arguments. This property set always has a type of SiebelMessage. You can pass the SiebelMessage property set from one business service to another in a workflow without knowing the internal representation of the integration objects. Property Set Node Types
When passing integration object instances as the input or output of a business service, you can use property sets to represent different node types, as presented in Table 51.
Table 51. Property Set Node Types
Service Method Arguments |
Not applicable |
Ignored |
The properties of this property set contain the service specific parameters, such as PrimaryRowId for the EAI Siebel Adapter. |
This is the top-level property set of a business service's input or output. The properties of this property set contain the service-specific parameters (for example, PrimaryRowId for the EAI Siebel Adapter). |
SiebelMessage |
SiebelMessage |
The properties of this property set contain header attributes associated with the integration object, for example, IntObjectName. |
This property set is a wrapper around a set of integration object instances of a specified type. To pass integration objects between two business services in a workflow, this property set is copied to and from a workflow process property of type Hierarchy. |
Object List |
SiebelMessage |
ListOfObjectType |
Not used. |
This property set identifies the object type that is being represented. The root components of the object instances are children of this property set. |
Root Component |
Object List |
Root Component Name |
The property names of the property set represent the field names of the component, and the property values are the field values. |
This property set represents the root component of an integration object instance. |
Child Component Type |
Root Component or Component |
ListOfComponent Name |
Not used. |
An integration component can have a number of child component types, each of which can have zero or more instances. The Integration Object Hierarchy format groups the child components of a given type under a single property set. This means that child components are actually grandchildren of their parent component's property set. |
Child Components |
Component Name
This property set represents a component instance. It is a grandchild of the parent component's property set. |
