Integration Platform Technologies: Siebel Enterprise Application Integration > Web Services >
About XML Schema Support for the <xsd:any> Tag
In the current framework, WSDL Import Wizard makes use of XML Schema Import Wizard to create integration objects to represent hierarchical data. Integration objects are meant to be strongly typed in the Siebel application. You are now able to import a schema that uses the <xsd:any> tag, which indicates a weakly typed data representation, and to possibly create an integration object from it.
