Integration Platform Technologies: Siebel Enterprise Application Integration > DTDs for XML Gateway Business Service >
Inbound DTDs for the XML Gateway Business Service
The following sections contain examples of DTDs representing the %methodName% response sent from the external application to the XML Gateway.
Delete Response
The following DTD is for the Delete response:
<!ELEMENT siebel-xmlext-dekete-ret EMPTY >
Init Response
The following DTD is for the Init response:
<!ELEMENT siebel-xmlext-fields-ret (support+)>
<!ELEMENT support EMPTY >
<!ATTLIST support field CDATA #REQUIRED>
Insert Response
The following DTD is for the Insert response:
<!ELEMENT siebel-xmlext-preinsert-ret (row)>
<!ELEMENT row (value+)>
<!ELEMENT value (#PCDATA)*>
<!ATTLIST value field CDATA #REQUIRED >
PreInsert Response
The following DTD is for the PreInsert response:
<!ELEMENT row (value)*>
Query Response
The following DTD is for the Query response:
<!ELEMENT siebel-xmlext-query-ret (row*)>
Update Response
The following DTD is for the Update response:
<!ELEMENT siebel-xmlext-update-ret (row)>
<!ELEMENT value (#PCDATA)>
Integration Platform Technologies: Siebel Enterprise Application Integration Copyright © 2008, Oracle and/or its affiliates. All rights reserved. Legal Notices.
