Transports and Interfaces: Siebel Enterprise Application Integration > Java Message Service Transport > About Multi-Step Operations Within a JMS SessionAll JMS operations are performed in the context of a transactional JMS QueueSession. If a send or receive operation throws an exception, the session is immediately rolled back. If the operation is successful, then the session is committed, unless the operation is part of a larger multi-step operation. In the case of multi-step operations, the transaction is handled as follows:
Each Dispatch operation is performed within a Siebel transaction. NOTE: ReceiveDispatch and ReceiveDispatchSend should not be attempted from within an existing Siebel transaction, as nested transactions are not supported. Also, as with all Siebel EAI receivers, if an operation fails during the execution of the JMS Receiver, the JMS Receiver component terminates. (A timeout is not a failure.) |
Transports and Interfaces: Siebel Enterprise Application Integration |
