Transports and Interfaces: Siebel Enterprise Application Integration > EAI DLL and EAI File Transports > About the EAI File TransportThe EAI File Transport helps move data between a Siebel application and an external file. NOTE: The EAI File Transport is different from EAI XML Read from File. The EAI XML Read from File uses a Siebel Message in Hierarchical format as the output property. When reading in data, the EAI File Transport uses a process property with Data Type of Binary as the output property by default; if CharsetConversion is set, it uses a string output property instead. |
Transports and Interfaces: Siebel Enterprise Application Integration |
