Transports and Interfaces: Siebel Enterprise Application Integration > EAI Transports and Interfaces Overview >
Using Named Subsystems for Transport Parameters
Named subsystems are groupings of defined enterprise parameters that are stored in the Siebel Gateway Name Server. You use named subsystems to specify methods and parameters for EAI Transports. Transport business services take two subsystem names as parameters, which you define using the Siebel Server Manager:
  • Transport Connection Subsystem (ConnectionSubsystem)
  • Transport Data Handling Subsystem (DataHandlingSubsystem)
Values for parameters in a named subsystem are common to every user of the subsystem across the enterprise. Subsystem names themselves are parameters for server components. You can logically group parameters into various subsystems.
For the two EAI Transport named subsystem parameters, ConnectionSubsystem and DataHandlingSubsystem, two parameters exist for the EAI receivers— ReceiverConnectionSubsystem and ReceiverDataHandlingSubsystem. The EAI Receiver looks up these parameters from the server component parameters and copies the corresponding properties (ConnectionSubsystem and DataHandlingSubsystem) to the input property set of the transport business service.
NOTE:  Parameters specified in business service user properties no longer work as is. You need to create named subsystems and specify the parameters for the subsystems. Then, you need to specify the named subsystems you created as business service user properties in a workflow or through an eScript, or the other usual means. Note that business service user properties work for the SAP Connector and the Oracle Connector business services.
