Transports and Interfaces: Siebel Enterprise Application Integration > EAI Transports and Interfaces Overview >
About Object Interfaces and EAI
Object Interfaces allow integration between the Siebel application and external applications. Object Interfaces can be called by eScripts and VB or used within a workflow. The workflow can use other business services and transports as needed. For example, the BizTalk Adapter might use MSMQ Transport as part of its workflow.
Available object interface support includes:
