Transports and Interfaces: Siebel Enterprise Application Integration > Using Siebel OLE DB Provider > How Scripts and Custom Applications Affect Your DataSiebel OLE DB Provider for Siebel EAI supports: This section explains how to use the Siebel OLE DB Provider with these technologies. After you have installed Siebel OLE DB provider library files and created your OLE DB rowsets as integration objects within Siebel Tools, you are ready to use Siebel data within the support framework. NOTE: Siebel OLE DB Provider allows you to retrieve information as needed from the Siebel data repository on a read-only basis. You can review the data and incorporate it into spreadsheets, databases, and Web pages, as needed, but you cannot make changes to the data and affect the Siebel data repository in any way using Siebel OLE DB Provider connection. |
Transports and Interfaces: Siebel Enterprise Application Integration |
