Transports and Interfaces: Siebel Enterprise Application Integration > Using Siebel OLE DB Provider > Installing the Siebel OLE DB Provider >
Viewing Siebel OLE DB Provider Events
After you have initiated an OLE DB client to connect to Siebel OLE DB Provider, you can use the Windows Event Viewer to review the events associated with Siebel OLE DB Provider and troubleshoot as needed.
To view Siebel OLE DB Provider events
  1. Start the Event Viewer.
  2. Select the Application Log.
  3. Look for events with a source of Siebel OLE DB Provider.
    There should be two information events:
    • The first event identifies Siebel OLE DB Provider DLL, ssceolpr.dll and the executable that loaded the DLL.
    • The second event identifies the connection string used.
