Business Processes and Rules: Siebel eBusiness Application Integration Volume IV > Creating and Using Dispatch Rules > EAI Dispatch ServiceYou can use the EAI Dispatch Service to:
The EAI Dispatch Service works with the hierarchy in the property set, which may be in some cases different from the hierarchy in your document. When dispatching XML documents, you should use the XML Hierarchy Converter because it generates a hierarchy matching the hierarchy in the XML document. NOTE: For details on the XML Hierarchy Converter, see XML Reference: Siebel eBusiness Application Integration Volume V. Use the business service argument tracing facility provided by the EAI Dispatch Service to understand the input property set hierarchy. This facility dumps the input and the output of the EAI Dispatch Service as XML. For details, see Testing Your EAI Dispatch Service Using Argument Tracing. |
Business Processes and Rules: Siebel eBusiness Application Integration Volume IV |
